I'm failing miserably at finding tutorials or videos on this.
I've bought some adhesive backed sign-makers' vinyl for applying to shelving, so it has a nice, even, bright gloss finish. But it's an awful lot more difficult than I expected to apply it without bubbles and creases, not to mention having it aligned properly. It's like trying to put a screen protector on a phone, but harder, given the size.
Any tips for doing this? I've tried applying it while the shelf (bare plywood) is vertical, horizontal, or at angles. Starting from the top, bottom, and side. Long side first and short side first. By hand, with a squeegee, and aluminium rod. It doesn't have lettering or anything, it's just a simple sheet with backing that peels off to reveal the adhesive side.
I'm sure it needs practice, but pretty pointless if you're not using a good technique to start with. How should this be done?
Thanks
