I am laying 12mm plywood on existing timber flooring (before laying Hardiebacker board & ceramic tiles). Apart from screwing the ply to the sub-floor, should I also use grab adhesive or thinset mortar?
The reasoning for thinset (I'm told) is that it helps to fill & support the plywood over any low spots in the old timber floor (18mm tongue and groove on 400mm c/c joists).
