I have two ceiling fans with two aftermarket light kits installed, all controlled from one single pole switch. So when switch is flipped, both fans and lights turn on or off at the same time. Only way to individually control each ceililng fan is to manually pull the chains. Is it possible to control the lights and fans separately using one single pole switch (switch that has fan/light controls)?
FYI - There is currently only a single black wire going from the breaker, to the switch, to the ceiling fans. I'm guessing some sort of canopy module would be needed? Is it possible to control the lights via the switch, but the ceiling fans via a remote system?
