14
I am trying to remove tile from the bathroom floor. It was installed in the 70s, and the pieces are tiny, 1 in x 1 in. I've been hammering away but they're not coming up very easily. Is there a product I can use to loosen them up?
    Is this tile laid on concrete or on wood? Have you considered removing the subfloor with the tile on and replacing it? – Freiheit Apr 16 '15 at 16:04
16
With these types of tiles you do not want them to break as they are harder to demo when they are in bits and shards. If you try to use a scraper (even power) what inevitably ends up happening is the top of the tile comes off, leaving the much harder to remove bottom on. Also this method severely damages the subfloor, sometimes to the point that you will have to put a new subfloor in.
What you simply want is a mallet or a hammer. Let me be really clear since I have demo'ed at least 50 of these bathrooms now and I think I have it down to a science.
  1. Start in a corner.
  2. Hammer the edge tiles flat. When I say hammer, imagine that you are playing drums in marching band, not hammering a nail. You want some force but not enough to break the tiles (they are usually hard to break when striking straight down). Bring hammer up 8-12 inches with each strike, hitting a small area repetitively.
  3. The first couple of rows might take 20-30 taps for a small group of tiles. This method does not "remove the tile", it removes the thinset bond to the subfloor. The tiles will just disengage from the floor.
  4. Don't just tap right at the edges. If I have an edge then I am tapping in a 6-10" perimeter in the area.
  5. Clean-up is easy since most of your tiles are in one piece. I can usually get a decent size floor demo'ed and cleaned in 2 hours this way.
Note: One of my contractors does this via air compressor and flat air hammer bit. After I showed him the method he went and got a flat bit that I think was made for pounding out auto bodies. You have to be careful with this because the force sometimes is too much or too repetitive and it will crack tile. I personally don't think it is faster but you could argue it is less labor intensive - he spends more time cleaning up. The hardest part about this type of demo is on your knees (I would pick hammer/knee pads over compressor/hammer bit).
|improve this answer|||||
    This really works. – iLikeDirt Apr 16 '15 at 15:47
Step one, which I hope you are already doing - put on a pair of safety glasses. You may also want earplugs, and gloves.
Use a masonry chisel (nearly parallel to the floor) to get under it and lift it up. You can also drive it into the grout joints, but if you already have a few tiles out, driving under the remaining ones from the area where some are removed is usually more efficient.
Picture from harbor freight - no association and no endorsement implied.
  • This is generally good for larger tiles but doesn't work well when trying to do the small mosaic bathroom tiles. You will end up cracking most of the tiles and causing more work. – DMoore Apr 16 '15 at 14:49
You'd be amazed how easily a bit of heat helps. Try a paint stripping heat gun and treat the tiles as if they were paint. Depends on the adhesive, but it might be the easy way to get them off.
