I have a switch i would like to replace with a timer like this
http://www.amazon.com/forum/-/Tx3DCN3HLSARWFS/ref=ask_dp_dpmw_al_hza?asin=B004SOZHXY
i only have a positive wire in my switch box,
could i use the (ground) box as a negative?
is it safe?
EDIT: i linked the wrong model above
would this do any better?
http://www.amazon.com/Honeywell-RPLS530A-7-Day-Programmable-Switch/dp/B004SOZHR0
    You cannot use ground as neutral without violating code. – Ignacio Vazquez-Abrams Apr 12 '15 at 17:50
    @IgnacioVazquez-Abrams I think it's worse than you think - it sounds like he wants to use the electrical box that holds the switch as neutral! But they do make switches that can be placed in-line (often labeled 3-way) – W5VO Apr 12 '15 at 19:58
No. The device you have requires a grounded (neutral) conductor to be connected to function. There's no other way to hook it up.
I believe Honeywell offers timers that don't require a grounded (neutral) connection. You might want to purchase one of those instead.
  • Yeah -- he needs an RPLS530 or RPLS540, not the RPLS730 he is trying to buy sigh – ThreePhaseEel Apr 12 '15 at 22:56
  • @ThreePhaseEel you're right on this one, i didn't notice the difference – YesItsMe Apr 13 '15 at 4:10
You do need the RPLS530A from the second link you gave for your application -- the unit comes with wiring instructions, but in short, connect the wires labeled C and 2 to the power coming in from the line, and the wire labeled 1 to the wire going out to the load (provided you're replacing a single pole switch, i.e. one with two brass screws and one green screw -- if you're replacing a three-way switch, follow the instructions in the manual carefully, and comment here if you need more help).
