I want to set up fan and light controls in three wall boxes, i.e. one fan/light control on each side of the bed, and one fan/light controller at the entrance to the room.
How can I do this?
    Is your fan and light wired with 1 wall switch that controls both the fan and light, or with 2 wall switches that control the fan and light individually? – ThreePhaseEel Apr 12 '15 at 1:14
  • New construction so I asked for two switches for light and fan. But I see not one wire hanging down from box – Natalie Apr 13 '15 at 1:55
  • are you talking about the switch box, or the fan box? – ThreePhaseEel Apr 13 '15 at 3:20
  • One fan and light on one side of bed, one fan and light switch on the other side of bed and ability to turn on fan and light at the entrance to the room. I prefer no remotes. – Natalie Apr 13 '15 at 18:09
  • I mean -- which box are you referring to when you say "But I see not one wire hanging down from box"? – ThreePhaseEel Apr 13 '15 at 22:09
This can be done using a multi-way fan/light controller system such as the Lutron Maestro series.
You (or your electrician) will need a MA-LFQM package, which includes the master wall module and the canopy module, and two MA-ALFQ35 accessory controls, as well as normal wiring supplies (two and three conductor cable of the appropriate gauge, wire nuts/connectors, etc).
The controls should be wired as per the diagram in step 12c of the instructions, and the canopy module as instructed. Note that you can't mix standard three or four way switches with these controls as they use power-line communications between each other and the canopy module to provide speed control and dimming, and you also will no longer be able to use the pull chain controls on the fan.
| improve this answer | |
