We moved into a new house last week. I was greeted with a faulty garbage disposal switch in the kitchen. The switch works intermittently depending on how hard it's pressed.
The second issue was the GFCI duplex receptacle on the right of the switch, was not working at all. A reset did nothing.
So I figured I'd replace the GFCI duplex with a new one from the hardware store. After installing that, the new GFCI would not turn on either, despite 120v power to the line terminals (as tested with my meter).
So I disconnected the load wires (pictured on the bottom), and the GFCI started working. The garbage switch continued to work (albeit just as flakey as before). Obviously the downstream receptacle (on the left) that was connected to load (on the right), wont work if it's disconnected.
So I'm wondering should I just replace the switch combo and wire it the same? Or maybe the thing is not wired correctly to begin with. Unfortunately I'm unable to ask anyone about what occurred here.
For reference this is a 2-gang box with 4 wires coming in (actually 5 if you include the ground on the left).
As they say though, a picture is worth a thousand words :) Any help would be great!
