It didn't work, so I put a new battery in the remote. Worked for several days, but then not today. Motor of opener did not engage (not a problem w/rollers etc.) I already checked the sensors and power source etc.
  • 4
    can you activate it manually? with the wall switch Apr 11 '15 at 13:51
    Did you double-check that the battery is making good contact in the remote? Is there any corrosion or build-up on the battery terminals in the remote? Any chance the switch is broken in the remote (is it very old)? Apr 11 '15 at 21:34
    I have a year old remote- battery seems ok. even when remote couldn't open it, the wall switch did. Reprogrammed remote again w/the motor and haven't had any problems in 2 days. Can't tell what the deal is. Thanks!
    – Ann F
    Apr 13 '15 at 3:20
    If you replaced the light bulb with an LED bulb...the door can malfunction. May 5 '20 at 4:44
  • I had this same question and REALLY didn't want to replace my garage remote without knowing for sure that it was faulty, and here is what I figured out: diy.stackexchange.com/a/228417/20576
    – Ryan
    Jul 2 '21 at 23:18
the most common issue with a garage door that just suddenly stops working is the motor capacitor. Its an easy and cheap replacement part. a usual symptom if a capacitor going bad, is a garage door that starts to get slower to open. sometimes this gradual slowing happens at such a slow rate that most people don't start to notice until it finally stops working. The best place to find a capacitor for you particular opener is inline or at your local Garage door repair shop. I can bet the repair shop will charge you FULL RETAIL price. I can't promise you that's whats going on with your particular situation, but I can say that most our issues with a sudden stop of an opener has been the capacitor. I hope this helps. Good luck to you
When the remote stops working but the opener still works from the wall switch and/or keypad, it's the transceiver in the opener that has gone bad. It's either part of the main control board or if separate, probably the most expensive board in the opener from what I've found.
For far less money, I bought a web switch that connects to my home wifi and mounted it next to the wall switch, wired into the same circuit in parallel. So now I use my phone to open and close the door, which actually works from farther away.
Do you have anything blocking the laser beam of the door sensors? If this plane is intruded upon by so much as a narrow garden hoe or some item, the door will not open or close.
