I recently asked a question about installing a dimmer and got a great reply. Now I want to install another dimmer, but this one might be tricky.
In our hallway there are three lights that are all simultaneously controlled by 3 light switches. enter image description here
I want to replace one of the 3 light switches with a dimmer so I could use that to dim the lights and the other 2 switches could just remain normal on off switches. Is this possible?
Here is the dimmer I want to use and its instructions: enter image description here enter image description here
I opened up one of the light switch fixtures and this is what I got: enter image description here enter image description here
So I have four wires going from the switch directly into the fixture. Looking at the instructions I can see what to do if there are 3 wires, but I have four. Can this work and if so how do I hook er up?
EDIT: Ok I read more about this and found that in this kind of setup there should be two 3-way switches and one 4-way switch. It looks like I opened up the 4-way switch right? So does that mean if I open up one of the other switches it will be a 3-way?
  • There are different kind of switches. So we would need a picture of the back side of the switch to see which cable is connected to which 'port'. (The 'ports' should be labeled btw)
    – User404
    Apr 8, 2015 at 13:34
    Yes, that appears to be the 4-way. Both of the other switches should be 3-way, and have only 3 wires (plus maybe ground) attached.
    – Tester101
    Apr 8, 2015 at 13:37
  • Ok I guess I can figure it out from here. I might post a pic of the 3-way switch and just confirm how to proceed before hooking it up.
    – red888
    Apr 8, 2015 at 13:40
  • What is the make and model of the dimmer?
    – Tester101
    Apr 8, 2015 at 14:19
