I recently purchased a house built in 2007. All houses in the area have those cables on the side of the house. The white cable on the picture is for cable/tv. But what about the blue/yellow cables? Are they safe to remove?
  • Is there any printing on the cables? What do the ends of the cables look like? Can you determine where the other ends of the cables terminate?
    – Tester101
    Apr 6 '15 at 15:00
  • Good question. I can't find the other end of the cables and I haven't noticed anything written on the cable (I'll double check that). I was quickly told that the cables were used during construction, but that's vague...
    – Martin
    Apr 6 '15 at 15:20
  • Is that siding? You might be able to follow those cables around your house to where they are actually used. When I moved in I found cables that started on one side of the house and snaked around to the other side through the siding. The entry point was in a completely different place than I expected. Looks like temporary power for "site lighting". Apr 6 '15 at 17:14
  • I'd ask the neighbours.
    – Gogowitsch
    Apr 6 '15 at 19:28
As best one can see from that resolution those are twisted pair cables. The blue is probably a Cat5e or Cat6, for ethernet, and the yellow is probably Cat3/VG for phone. If you look closely you should see the rating on the jacket.
If your area has or is scheduled to receive fiber-optic com utilities then some vendors (like FIOS) put the fiber terminal outside and split off the various services from there.
If they're not connected on either end they're safe to remove, but I'd leave terminals in case you want to connect service so you don't have to drill back through the siding.
With the limited information provided, they could be anything. Likely they are for telco, but could also be for monitoring your water meter, or could part of an alarm system (fake phone line that triggers an alarm if cut). It could also be speaker wiring or some other low voltage wiring.
I would suggest you leave it until you know for certain what it is. If you were to remove it, and later had a need for it, you would need to run new wiring which could involve cutting walls and drilling another hole through your siding. Extra wires are usually a good thing that you'll be happy to have at a later date.
As one of the commenters suggested, one of your neighbours probably has an idea what they are for.
I finally found out what those cables are. They are simply CAT 5 cables. They were used by the Frontier technician to install FiOS.
The blue/yellow color is just to distinguish the cables.
