Here is a picture of the light dent
I had created this small dent in my door and I am wondering how to fix it.
    What type of door is it; I mean from the inside? Like is it a solid wood (I doubt it is)? If it is just a wooden frame with a panel fixed on it you can put a foil specialized for this purpose. This will mask the dent, but generally speaking those doors are poor quality if it is an option for you maybe you should replace them. – python starter Apr 6 '15 at 8:40
You could try a steam iron over a linen cloth it works on dents on solid wood. I appears on the picture your dent might be a break in the wood. Give the steam a try.
