I wanted to change the light fixture in my front closet. Simple enough task. I've done this sort of thing hundreds of times.
I turned off the circuit breaker. I took the old fixture off. However, I found that the wires were whole with only a small piece of the plastic/rubber covering peeled off from the center from each color. One wire was white and the other yellow. There are no ends to you would typically find. I thought it was odd but just went with it. I wrapped the white wire from the new fixture to the white wire in the ceiling and the black wire from the fixture to the yellow in the ceiling. Long story - short...When I turned on the electricity the circuit blew. Needless to say what i thought would work, didn't.
I hope all that makes sense. I have not idea how to resolve this, considering it should have been easy.wiring in ceiling. i taped the exposed partthis is the old fixturethe new fixture is on the right
If the old fixture worked, Then you should be good if all is connected properly. When you say you "wrapped" the new wires onto the wire in the ceiling, I take it you mean just that, and perhaps taped them up (given the first picture) - I'm guessing they came untaped and shorted out when you put the fixture in place.
Cut and strip the wires in the ceiling, and use a correctly sized wirenut or other suitable wiring connector to connect them to the fixture wires.
  • What happened is the wires were stripped midway and wrapped around the fixture screws on the original fixture -- so yeah, he'll need to cut the wires and use wirenuts. Apr 6, 2015 at 1:47
  • @ThreePhaseEel I understand what was done on the original fixture. It actually works fine for screw connections (though it's not generally accepted), but a cut, probably a restrip, and a wirenut is required to make it work for pigtails, which the new fixture has.
    Apr 6, 2015 at 1:56
