It is in apartment on 10th floor. I suppose it may be the ventilation tube, but I can't understand why the ventilation tube has such a thick walls. And why it ends there, instead of going to some grill in the ceiling...
    Any chance you can get a closer shot of it? Also...ewww at the NM in a high-rise apartment building! – ThreePhaseEel Apr 5 '15 at 7:48
  • So far there is no way to get a closer shot without opening the ceiling.:( I've made this shot after opening the outlet which looks like ventilation grill but has nothing connected to it. – Jim Apr 5 '15 at 9:40
Looks like a plenum return to me, especially since you said there's a ceiling grill into this area. Basically the false ceiling is acting as part of the ductwork. Very common in commercial buildings, less so in residential... but not at all unreasonable.
    Does make the "not remotely plenum rated" NM wire look even worse, though. You won't die from the smoke off the network wire (if it's the usual blue=plenum wire) but the power wiring will do you in...ewww indeed. – Ecnerwal Apr 5 '15 at 20:56
  • What, you:re expecting the typical cable installer of landlords to have a Clue? ;-J – keshlam Apr 5 '15 at 21:35
  • No, I'm just sad to see the results of a throughly bribed building inspector endangering more lives where code has "solved" this particular means of killing people... If it was followed. – Ecnerwal Apr 5 '15 at 21:39
    Not until there's a fire... at which point flammable and dripping plastic will make the problem worse ... – keshlam Apr 5 '15 at 21:48
    the toxic smoke from the burning plastic makes it worse faster. The insulation on plenum rated cables is not quite fireproof, but has a low level of toxic smoke production compared to "normal" plastic insulation. The thick walls on the tube are almost certainly (thermal) insulation, as has been mentioned in other answers/comments. – Ecnerwal Apr 5 '15 at 23:16
Looks like somebody forgot to connect an HVAC supply duct -- probably to the vent you opened to take the picture! The "thick walls" on the duct are probably insulation, which is why I suspect it is a supply duct.
