I'm looking to buy pop rivets to do some gutter replacements, but the smallest "advertised for gutter work" pack available was a 100pk. I'd probably only need 20 at the most (short span). There weren't any dimensions listed, but common sense says they would only need to be around 1/8" x 1/4". Assuming any substitutes should also be aluminum.
What size would be adequate for joining aluminum gutters?
It depends on your gutter brand's seam overlap. A narrow riveting area should prompt a small rivet (1/8") because you do not want to drill a large hole (for a thicker rivet) which could weaken the gutter material in the riveted area, causing failure of the gutter material under stress.
The grip range required is determined by combined material thickness.
I recently used 1/8" (3mm) wide, 1/8" (3mm) grip aluminum rivets for fastening aluminum gutter end caps on. Worked great.
I definitely wouldn't go much wider than 1/8" for fastening gutter end caps because there is only about 1/2" of aluminum to fasten to.
    Gutter caps crimp on. And still have to be caulked. – BillWeckel Oct 9 '18 at 20:33
  • @BillWeckel I've seen lots of professionals on youtube using special gutter end cap crimpers, but I didn't want to buy a $50 CAD tool that I would use only once. Or did you mean just crimping with regular pliers? – afk Oct 11 '18 at 14:27
  • You can just use pliers too. Hell, I use a downspout crimper, but I've used whatever pliers I've had laying around too. Like i said, the end caps still have to be caulked, which will hold the end cap in place once it dries. – BillWeckel Oct 11 '18 at 14:41
Why not use self tapping sheet metal screws? You've gotta caulk the inside of the gutter at your seams and end caps anyway...
  • Screws protrude inside trapping debris and leads to clogged gutter down spouts. Screws are the Worst Fastener For Gutters! – Stan in N. Fla. Jul 12 '20 at 15:34
  • Not so much protruding (rivets also protrude, but less). I had a customer who had a problem with screws rusting out and leaving nasty stains on her nice block paving. Took the screws out and put aluminum rivets instead. – sleblanc Aug 4 '20 at 12:46
