I have a country style front porch that has non structural wooden columns that are anchored to the overhang and hang to the floor, a concrete pad. To stop the columns from moving around the builders wedged a shaved 2x4 between the column and the concrete. A railing is strung on the columns. Depending on the temperature decides how sturdy the columns are held in place and if anyone puts any weight on the railing a column will swing around. How can I fix this?
When I fixed my 4x4 posts (covered with vinyl covering), I used a bottle jack on a piece of 4x4 to lift the roof section about a 1/2" or so, then placed the support underneath, then let the jack out to have a little bit of down pressure on the 4x4 and post base. This helped keep the posts in place for the last 8 years without issues. I guess that settling had finished as well, so there you go :D– Pᴀᴜʟsᴛᴇʀ2Apr 3, 2015 at 20:54
1 Answer
A post base. There are several styles, this is one.
