I seem to have a fairly large chip in one of my foundation cinderblocks.
Foundation Cinderblock closeup
Foundation cinderblock further away
Is this type of damage repairable as a DIY project?
This doesn't look like foundation damage. This is a settling of the pathway around your house. Good news is that it doesn't look like serious problem, at least from what I can see from the picture. This issue should be fixed because it will only get worse, and then rain water will go under you foundation and that could be a problem. You should demolish pathway preferably all of it, if not than at least parts that have sunk. Then, pour some gravel and compact it. Over this layer you can pour concrete, of course use reinforcement meshes, so the new pathway wouldn't crack. Also, I like to divide these paths every 2-3 meters with a piece of wood or even better with Styrofoam which I take out after concrete has hardened. These way pathways can "breath”. I forgot to mention that it should be under slope so that water would go from the house.
  • Thank you for your reply. After rerouting the water and repairing the pathway should anything be done to repair the block? I have had a colleague mention hydraulic cement could possibly repair it.
    – xsixteen
    Apr 3, 2015 at 17:47
  • From the picture (second one) I can't see the block damage. I’m not sure what’s on the first picture. My guess is that it is the bottom of the wall where it meets pathway. Anyway repairing the block isn’t something crucial but yeah you can do it, well after all anything on your house shouldn’t have cracks, right. You can use "stronger" cement mortar to fix this, or some specialized product but they are expensive and I don’t think there is a need for such product. Apr 4, 2015 at 18:02
