I'm replacing an electrical box in my bathroom that connects to both a vanity light and a fan. The idea is to put in a GFCI outlet and a duplex switch for separate light/fan switching.
Right now I'm stuck on grounding:
I have three ground wires coming into the box (line, light, fan). Plus one to ground the box itself, plus one each to the GFCI and the switch. That's 6x12 AWG wires that all need to be connected.
How do I connect that many wires? The largest readily-available wire connector (red) is rated for 4x12 AWG.
