I've a Type C electric socket that not holds solidly in a wall slot.
It uses metallic lateral ears and a pair of screws which controls their angle to hold itself into a wall socket.
Wall socket is concrete.
Is there any way to fix it solidly into this wall socket?
  • 4
    A photo or two would be a tremendous help toward getting folks up to speed on your problem. – Michael Karas Mar 28 '15 at 11:20
  • Use spacers. – Mazura Jul 27 '15 at 2:22
You can use a 90 degree, type C plug
And then fasten to the wall, with a couple of cable clamps
A clamp close to the outlet and it will be difficult to remove, and clamps down or along the wall will keep it safe.
Hope this helps
