I had a Kenmore dishwasher installed in January, in less than a month we had a repair call because the inside of the machine was always wet and was stinking. The repair man said the new machine needed to be seasoned with the rinse agent being wiped on the entire inside of the machine. Said it would be okey in a matter of time. It still stinks and am having a nightmare with Sears to get this resolved. Their install people came back out and on the bottom of the machine, there is a cup thing that was full of water, up to the level of the machine. He said that much water should not be there, and to get the dish washer replaced. He said a little water was fine, but not over 3 inches of water. The hose under the sink is not looped up, but the hose is looped over the dish washer under the counter. The repair supervisor at Sears said the standing water should be there so smell doesn't back up. I am really questioning his expertise on this issue. They are sending out another repair tech to look at the dish washer.
[Question: who is correct? Is some standing (and stinking) water in the dishwasher normal or not? Would this be a defect in the machine, or in the way it was installed? And if it isn't normal, how can I get Sears to take responsibility and fix it?"]
