I have a 2 car garage about 20 by 20 in size. Planning to build an attic storage/bonus room above it.The space above garage measures about 18 by 20 with minimum hight of 6 feet, and an access can be build from 2nd floor hallway/bedroom. Should I worry if the foundation of the garage is strong enough for the attic, before reinforce the attic floor?
Thanks so much in advance for your answer.
That would depend on how good the foundation is. Normally, the foundation is adequately overbuilt that it's not a concern. The weak link in this sort of conversion is USUALLY the "attic" floor above the garage wich is typically marginal even for light storage, and far from occupancy loads, over a very long span. Bringing that up to an adequate structure is a significant project if it was not built as such from the start.
