I have 2 switches in my bathroom: a fan (power comes into the fan and it's just a simple black/white to the switch) and a switch/outlet GFCI combo where the switch powers the lights but the outlet always has power (power comes in at the box with separate line to the lights)
It seems very backwards to anyone hitting switches that the small switch is the lights and single large switch is the fan, thus I want to swap them.
First, based on the configuration, is it possible to do a simple swap for the switches? I don't care if the fan would be GFCI protected or not using that switch. However, based on this question I have a feeling it's not possible? (Apologies if this isn't possible and you'd consider the question a duplicate, I'm being optimistic this situation is different enough I can rewrite it)
If it is possible can anyone point me at a diagram on how I'd wire this up? If helpful, here's a picture of how it's wired now (power in, lights, fan)
