I have a covered terrace that extends 10' out (West) from the house towards the yard/pool and has a width/span of 32'.
The current beam is made up of (2) 2x6 in wood placed side-by-side functioning as the beam. It is currently supported by (4) 4x4 wood posts which are rotting away. The beam supports (17) 2x6 joists. The joist spacing is 24" O.C. for all except the last two on the North side of the terrace which are 20.5" O.C. and the last joist which is 15" O.C. The joists are holding the usual 4x8 plywood sheets for the shingle roof.
I would like to replace the existing wood beam and posts with steel. However I would like to use only two posts on each far end (probably a foot or so in from the end of the beam on each side). This way there would be no posts blocking the view.
My concerns are due to the span and weight. I want to avoid any sagging of the beam in the middle. I also want to make sure the structure supports the weight and wind uplift (in a hurricane zone).
How do I calculate the correct steel beam and posts sizes and footings needed for my purpose?
[Photo 1] Standing on North end facing South: Standing on North end facing South
[Photo 2] Standing on South end facing North: Standing on South end facing North
    What's the rationale for wanting to use a steel beam here? Wood is cheaper, easier to work with, easier to obtain, and can be designed to withstand the relevant wind forces. In single-family residential construction, steel beams are typically reserved for unusual circumstances requiring very long spans.
    – Hank
    Mar 21, 2015 at 2:32
  • From my understanding, a steel beam is the best option for a single 32' span. My goal is to have only two posts instead of four as I currently have. I also want to avoid having to replace the wood beam due to potential termite damage or rot in the future. If a single wood beam can be used, I'm open to hearing the options that could work. Thanks! Mar 21, 2015 at 2:42
4 Answers 4
I can provide you with the answer that comes is the result of college statics and dynamics classes.
What I can not do is provide you with an answer that carries the weight that would be provided by the stamp of a public engineer licensed to practice in the state of Florida, or your state of residence.
In all sincerity, I would ask that you not accept the word anyone who has not already approved residential construction issues in the City or County of your residence. And even then, do not take their word as accurate until you have the data in writing.
Hurricanes, slow or no insurance payments, and political inaction seem to happen at the same time.
My in-laws lived between I-95 and the Ocean, in Palm Beach County. I think the biggest difference between their house and yours, is the pool edging not being flush with the deck, and the house next door was a different color.
Realize I am guessing about everything from ASTM rating of the steel that would be used, to the hurricane wind design rating required in your zip code.
I would not blink if you were told that it needs a heavy 4 or a standard 5 inch beam. The 5 inch beam is less than 1/4” larger on each side. So we will go with that one.
I know nothing about the most recent building code and large pieces of steel around residential pools. But I will bet that 32’ bits of it weighing about 325 pounds and raised in the air, on steel, are not allowed within 6 feet of the water.
I am sure that there is now something about needing enough space to walk all the way around the perimeter of a pool.
There is likely also something about footings, saturated soil, flying debris, and the term ‘grounding’ will be used at least twice. If we add 6 feet to each side, we are well inside the bounds of reasonable.
We have now hit a 44’ clear span.
It gets a little tough to tell distance, but I am (again) guessing that this will put 1 post over your pool pump water works, and the other in front of the bathroom window. You are not going to be able to move the post closer to the pool, but I am open your thoughts.
The question is now, what are you going to do about the beam that will now overlap with your eaves. The easiest answer it likely to wrap a hollow fiberglass post around the steel one. Then paint it blue and hope it is not noticed.
Since you are changing the patio roof so much, from the materials used, the distance between the supports, the additional length, and joists now being attached to steel instead of wood. I would expect the patio roof to be seen as new construction and not repair. This will require the patio roof to be self supported. This is much better for you than the alternative of having the patio roof seen as a part of your house.
It appears from your pictures that the house side of the patio roof requires the outside wall of your house, and is even attached to it with hurricane straps. The 2x on the wall, but connected to nothing else seems to be there as an attachment point should you want to put in a flat ceiling.
To recap up to this point, removing the 2 center posts and replace it with a single steel beam spanning the entire distance, you will need to build a 4 post, self standing, cabana type roof.
It can be against your house, and the roof can be integrated into your house, but it must be able to stand on its own.
In reality the posts closest to your house will need to be far enough away from your house that they will not disturbing you house’s slab. (But you might be able to offset the footing enough that the post can be right against the house. Way too much math for right now.)
Ok, at this point, it makes no sense to build anything but a rectangle of steel, and put it up on steel legs. You will need ’notches’ to allow for both ends of the new roof, to make room for where your house becomes wider.
You will need to decide what you want the roof to look like, the notched portions will be the hardest. Thanks to this now being all steel, you can add gussets, strengthening web where needed, this will help to keep the beam size down.
We still need to deal with the new joists, roof and shingles, there are some other decisions to be made first
The costs at this point are likely in excess of the quality of life you gain in having the 2 wooden posts removed.
It would be informative to call planing and zoning, and ask if they can think of any issues with you installing about 32’ of steel, where the posts are within 6 feet of a pool. The answer would allow a few facts to get involved here.
And this is how we truly figure out what size beam you need.
  • I appreciate the comments and thoughts. The main reason I'm asking the question is to learn, this really interests me. The second reason is that I would like to know that things are done right. Personally, I really hate not having any idea of what to expect when I'm having people quote me. As for the pool coping, it will be flush with the pavers once they are installed. I didn't want the pavers installed until I solved the beam/posts issue. Mar 21, 2015 at 2:38
  • Really appreciate your time and effort on this answer. What seemed like a smart and quick job turns out to far from it. Isn't that the case all too often? Do you know I'd there is a wood solution for this? Mar 22, 2015 at 2:31
    This post is too long and badly structured. If really every single sentence is needed, add structure to it by using headings, otherwise, delete generously. Apr 30, 2017 at 21:41
The exterior wall is the true support. Otherwise the 4x4 would be under the 2x? Load is transmitted vertical. Ya don't notch it.
For each 4x4 removed add a 2x? The entire span. Support the end of the span with the entire width. Use 8 ' 2x and cut the first on in half (4') so the joints stagger. Use 3/8 lag bolts every two feet starting 4" from each end. Three bolts every two feet. Two from the left and one from the right on the first one then switch at the next station two right one left. The lags should not protrude but penetrate all boards. The last set of lags will be 4" from the end. You can also glue if you wish but the above is overkill based on the pics and the description.
Use hurricane ties on all boards.
The 4x4s are just sitting on deck. My greatest concern would be to spread the load at each end over the week deck.
Just my opinion though
  • Great answer for what size wood beam is needed but it is not an answer to the OP's question of how to calculate what size steel beam is needed.
    – Alaska Man
    May 21, 2017 at 16:41
It seems to me that what you want to do is possible. A single steel beam can easily span 30 feet. Individual timbers are relatively inexpensive, but steel is so much stronger that you need much less of it. It even may be less expensive than replacing the wood with wood.
To do a rough estimate, get a copy of The Architect's Studio Companion, which is a compendium of useful rules of thumb. (You can always get it on inter-library loan, if in no other way.) A more detailed and accurate answer can be found from codes and structural engineering textbooks. Code often provides rules of thumb ("prescriptive requirements") which allow you to avoid the effort of engineering calculations. I am not a structural engineer; if you are serious about this it would be best to consult one. Steel has to be protected from water, and sometimes fire as well, and that is also covered by code.
Call 3 or 4 contractors out asking for bids with details as to how they will do the job and if it will be approved by all local AHJ's. Tell them you are open for options in wood if you can obtain the view you desire. You will then know how you might be able to DIY.
  • Hello, and welcome to Stack Exchange. As a contractor (in another field), this seems a bit unethical to me. Mar 28, 2018 at 23:22
