I had someone come take a look at the attic yesterday to do an assessment. He uses the sprayable foam insulation and said that he would spray the ceiling of the attic rather than the floor (and remove the old insulation) and close up the two attic fan vent areas. He called it a "ventless attic" and I've never heard of this before. He claims it's safer and better for air circulation. Has anyone ever heard of this? Also, does it make sense to remove the old insulation or could it be kept there? I worry about all the dust and debris it would leave behind upon removal.
What he's suggesting would be to make the attic inside the building envelope, therefore you'd be heating and cooling the attic along with the house.
You either need insulation at the attic floor or attic ceiling. One or the other is the building envelope. If you google some of the terms you can learn a lot.
If the house is a standard, single open roof I'd vote for keeping the insulation on the floor.
Maybe get a few more opinions?
  • Couldn't one argue that this provides a poor solution in the winter? When the heat is on the air will rise unfettered all the way to the attic ceiling rather than being insulated at the base and providing warmer conditions below the attic?
    – mjt117
    Mar 18, 2015 at 18:17
    warm attic means having to be careful to keep the actual roof cold , or you risk ice dams. Also means having to change how and if you vent the attic. Can be done but it's a distinctly different set of tradeoffs; generally makes sense only if you really want the attic to be heated/cooled space.
    – keshlam
    Mar 18, 2015 at 18:57
