I want to use the space under my deck for entertaining when its raining. What would happen if I used one of the thick bed liner type wood coatings and simply applied it to the decking and also into the gaps, After a rainstorm I was thinking the water would evaporate or I could squeegee it off, I also thought about installing a composite type material underneath the floor boards between the joists to eliminate the coating from dripping through the cracks while it is drying. After it all dried I would possibly remove the composite material and coat the underside of the deck.
So could you give me any reasons not to do this?
