I had the end cap crack on a 2" irrigation line buried 1-2' underground. It sprayed downwards, clearing away 2' of dirt vertically (3-4' total downward now). I found an area about 3-4' away from this site that also had water rushing up from it, so there is at least a 3-4' deep horizontal hole as well, all within feet of my patio and pool pump cement block.
How do I fix this?
I live in Tampa, FL. Ground is kinda of a dry clay/sand kind of dirt.
Right now, my idea is to carefully dig up where I think the hole is so that there's no cavity down there. Flush the broken line. Re-PVC-glue it was a new end cap. Refill hole it with some clay/compact dirt filler.
Schematic:
1'wide hole 2" hole
1-2' ======] | | |
/ X \ 3' | |
| | X is side of crack
4' --------------------------|
estimated cavity
