I want to make a LEDstrip(RGB, 300 LED, 3528, 5 meter) At the back of my 40 inch television. But I have some struggles finding out what I need for that.
I have found this strip: LED Strip
And I Found these connectors: Ebay.com
I can't seem to find any: 3825/8mm RGB plugs or anything like that.... But is it Universal? Some Ebay sellers say that it is for both, but I've also seen posts which say it doesn't match.
I hope someone can tell me if I can use the: 5050/10mm RGB connectors also for the 3528/8mm strip!
  • Just an FYI, but 5m and 300 LEDs is a little overkill to go behind your TV... Why not get a pre-made system for ambient backlighting? Some are white only, but many are RGB.
    – Hari
    Commented Jan 12, 2018 at 19:50
No, you can't mix and match 3528 strips/connectors with 5050 strips/connectors.
Even within 5050, RGB vs RGBW use different connectors, and there are even W-only strips in the 5050 form factor, which use a different connector still.
Put more of an effort into shopping, and you should be able to find the right items more easily. EBay/AliExpress are not necessarily the best places to shop.
