So I removed the old broken 4x4 post that was for the fence and deck. I have the deck sitting on stone slab after I held it up with a jack. It had two bolts that I had to cut out that are still in the holes for the deck framing so I cant put the new 4x4 post back in the same way to attach it back to the deck. Any ideas on what to do?
    Can you better explain what is at the bottom where the new post would go? Maybe add a photo? I am trying to understand what is there to fasten to. – wallyk Mar 12 '15 at 7:25
  • Drill new holes? – Tyler Durden Mar 12 '15 at 13:26
Use a sledgehammer and a large punch to drive out the old bolts. For one-time use, a spike just smaller in diameter than the bolts, with the tip cut off flat may work well-enough at a lower cost, if you don't have a large punch on hand.
| improve this answer | |
