I have a small 5th floor flat, with high ceilings. The sash windows, which are tall, face south. There is a very busy road underneath the windows. Two rooms have these windows.
It's noticeable that I start coughing as soon as I get into the flat. And my girlfriend starts sneezing and getting a blocked-up nose. Obviously from the traffic pollution from outside.
Spring is about to start and soon it's also going to get pretty hot and uncomfortable, since the windows make it like a greenhouse.
What would be the best solution to tackle both the pollution and heat, bearing in mind that it's a small flat, and I don't think I'm allowed to mount any kind of unit on the outside of the flat.
Is there a joint aircon & purifier that I can connect with a hose, which is reasonably quiet? I'm willing to spend a bit to get a nice air environment.
Room 1: 365 X 365 X 365cm, 12 X 12 X 12 feet
Room 2: 365 X 190 X 365cm, 12 X 6 X 12 feet
Pollution and Heat
│ Window 1 Window 2 ││ Window 3 │
│ Room 1 ││ Room 2 │
