Is it possible to install interlocking vinyl flooring on a home with not exactly level floors?
The home is 100+ years old and would require a major upgrade to make the floors completely level.
I'm looking to make an economical upgrade to the bathroom floor which currently has hideous sheet vinyl floors.
Can I use interlocking vinyl floors on a surface that is not exactly level?
Floors don't have to be level for click-lock flooring, it just needs to be flat. Manufacturers will give you the maximum floor change per foot. I suggest that if you have small dips that are outside the manufacturers ranges you fill those with a self-leveling compound.
@DMoore self-leveling compound will not help him, in fact it can cause more damage than good if applied on this type of floor...with the rest I agree. If you want to fix dips you better use something like putty – python starter Mar 3 '15 at 18:39
