Our 1954 home has very narrow soffits, with metal over them. The best solution I've come up with for adding soffit vents is 2 inch hockey puck style. I did a few several years ago and stopped. See photo:
I'm now committed to doing all I can this spring/summer. I've searched for full length soffits as narrow as I need but best I've found is 4 inch until I looked at my next door neighbor's house! See photo: enter image description here
I think I could just buy standard soffits and cut them to do the same. The question is how to remove my current metal soffit and then cut the wood soffit that's attached to the rafter tail.
Do I use a tool to just cut what's there, and if so with what tool? Not sure how I'd slip the new one in though.
Otherwise, do I remove the gutter than then take off the front piece, hoping to expose the nails to pull out?
I can only advise you on what I think you will find.
You already mentioned the best possible way to start correcting the situation, remove the gutter and finished fascia, but you cannot stop there, you will need to remove the top piece of siding that meets the soffit as well. My thought is, the metal soffit is very thin, and the soffit that you neighbor has, is standard soffit material that is available perforated to give the ventilation you need. It is 5/8" thick, so it will not fit in the same space the thinner original soffit does. The nails holding the last piece should visible at the very top, just under the trim strip.
When you remove all this you will have access to the sub fascia to check its condition. The ice forming behind the gutter, is not a good thing, water may be getting behind the metal and rotting the sub fascia, so it is worth a check. On your neighbors picture, the ice appears to be coming over the front edge only, where it should be. Since you should be going with the thicker soffit material. you will need to remove the track at the wall too. The soffit will be a little lower since it will contain the 5/8" soffit, and any damage you create on the siding from its removal can be cut off. After all the soffit is installed new, set a new, or possibly reuse the original "J strip" at the top hide the edge of new soffit at the wall and to capture the top edge of the siding after it is trimmed off to its new dimension. Set in place with new nails like the originals, pilot first. The old hole may have been cut off by the needed trimming, or at least hidden better by the "J strip".
That piece at the top that caps your siding now may be a "trim strip" very thin, maybe 3/8" thick at the most. If that is the case, you would do well to add 2 "J strips" or an inside corner specifically made to handle the soffit and siding going into it from both directions. You may be able to do this with one J strip, add it after the siding is on WITHOUT trimming it as mentioned before. Slot the nail hole to allow expansion and contraction. Set the j strip to the rough soffit to hide the top of the siding, set the soffit material and set the fascia and gutter last. There is a small chance the last piece has been "dimpled", and is held in place by locking into the trim piece, Ease out the trim piece edge and it MAY come out. If it is caulked in place, it will be a bear to get out.
You may need to get a taller piece of fascia to accommodate the 5/8" taller face you just created, it may need to be taller any from the symptoms where the ice is. If not the gutter may have not been installed so the front edge is HIGHER than the back, it is not supposed to be. Typically the back is high enough to put the back edge, IF possible under the drip edge so any runoff of the roof is forced into the gutter.
If you want to consider an alternative that you may retrofit easier and may look better too, is this line of continuous soffit vent. This link is for a full box, but you may find a smaller quantity elsewhere. It is made to set in with a thin plywood soffit, but the edges can be cut off which would make it quite flimsy, or you could finish making the bend that would "hem" the edge making it a bit stronger. Razor knife the section at the wall, remove the soffit and gutter, which I think would be a good move to inspect the framing. Pull the nails if any holding it in place at the fascia, work the old soffit so the score mark you made at the wall will flex and the old piece will come down. Take care not to distort the edge you cut, bends here will make trouble trying to get the new piece in. Slip this stuff in under the cut at the wall, between the old soffit and trim strip for the siding and tack it back in place before you reset the fascia.
  • Thanks Jack. My neighbor had new siding this past summer, I'm guessing that's when they did it. Any thought on if 2 inch vents would be better or worse for ventilation? Certainly sound easier.
    – user20127
    Commented Feb 28, 2015 at 21:20
  • Yes it would be much easier. 2" round vents will certainly help. The venting they allow is small, so the more, the better. You may want to consider a continuous soffit vent. I will include that in my answer later today. I will make a sketch.
    – Jack
    Commented Feb 28, 2015 at 23:21
  • Thanks, I look forward to your sketch. I'm also considering just cutting out the inner flat section and then attaching a piece of venting lengthwise, if I find something about that width in one flat section.
    – user20127
    Commented Mar 1, 2015 at 15:53
  • That is what the link is in my edited answer above, the link is in blue letters "continuous soffit vent". The sketch I realized after I made it would not help with replacing it with flat metal, in cross section it would look the same. The sketch was going to illustrate a thicker material and how it finally fit in.
    – Jack
    Commented Mar 1, 2015 at 17:49
