My contractor just completed replacing the tub surround. the walls are tiled from the tub to the ceiling.
A few things I'm not too sure about, and would like to get some opinions.
The contractor did not silicon caulk the edge between the upper tile wall and ceiling. Just grout it. Granted, due to some shifting walls, the ceiling needs to be repainted in spring and you can't paint on silicon caulking. Just wondering if the lack of caulking would cause issues.
The silicone caulking was applied to the tub edges while the grout was not fully dry (he did it about an hour or so after he finished grouting). It has been about 8 hours now, While all the other grouts have dried and lightened, the ones under the clear caulking is still dark. Would the calking interfere with the grout curing process?
Thanks.
