I bought a house, and two of the closets are missing the door handle/knob. It's a mortise lock (old house), and every other interior door in the house has the same handle, so I'd like to not get one of those glass ones that seem widely available and instead get a matching replacement for consistency throughout the house.
I've browsed dozens of pages on amazon, Schlage, Baldwin, etc.
This is the hardware kit. The only part missing is the handle: Mortise Door Hardware Set
Here is a door with the missing handle: Door with missing handle
closed as off-topic by Tester101 Feb 20 '15 at 5:22
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions seeking product or service recommendations are off-topic because they tend to become obsolete quickly. Instead, describe your situation and the specific problem you're trying to solve." – Tester101
If this question can be reworded to fit the rules in the help center, please edit the question.
  • I disagree. First, the situation is clearly described, and the problem is as specific as is possible. Second, although the first response does recommend a specific product, my original hope was actually that someone knew of a general website, search, or method that could be used to track down this sort of information. It could be applied not just to door hardware (my specific case), but any/all antique hardware & fixtures. – Griphus Feb 20 '15 at 13:54
Looks close enough to me (buy two, do both sides). Also, consider swapping a new one with the inner knob from one of the closets or any other less conspicuous door. If you don't like this one, search Google (not suppliers) with these key words:
Beaded Oval Door Knob: (rejuvenation.com)
