So yesterday I had to replace the handle on the shower-- and because I couldn't access the valve to the shower, I had to shut off the main valve to the entire house. I switched out the handle and everything is great. Except now the same bathroom with said shower has a sink that no longer has any water pressure. I.e, it just trickles water, both from the hot and cold valves (If I shut off the cold valve, it will trickle if I move it to hot, and it will turn off when I switch it to cold-- and vice versa with hot)
Every other sink, bathtub, shower, everything has the appropriate water pressure.
I'm worried that I broke something, but I have no idea. I don't see leaks anywhere, nor do I hear any leaks. House is at 64 so I don't think anything froze? Anybody have any ideas what could've happened?
Thanks in advance!
