We bought an older home and completely renovated it about 18 months ago. Now I am starting to see small cracks in the drywall in the ceiling and walls. What could be causing this?
    Are the cracks running along a seam in a flat surface or at corners?
    – bib
    Feb 18 '15 at 22:20
  • Does your house have a whole home humidifier? Lack of humidity can cause this. Also check to make sure it is working and maintained.
    – Mnc123
    Feb 19 '15 at 2:12
  • Were the cracks smaller during the summer? Is it related to seasonal changes in humidity? Or are the cracks growing and growing?
    – wallyk
    Feb 19 '15 at 19:30
I am not a structural engineer. I'm just a homeowner/remodeler. This kind of diagnosis requires a site by a structural engineer. If you are really concerned about your house, I'd recommend hiring one for an hour or two to visit your home and provide their opinion. Cost is likely $125-$250. Don't get talked into making complicated drawings for lots of money unless they see that there is a problem. You may already have some drawings if you had a permitted remodel.
However, I can talk about what might generically cause issues like this in a house.
There is, as BrownRedHawk suggestions, the benign explanation. These crack could be normal signs of age, material expansion, or harmless settling. If these cracks are primarily at corners or in lines at seams in the drywall, then they may simply be a bad mud job on the drywall. Even how you hang the pieces around doors and windows can significantly affect cracking. If it is the benign problem, you could probably just have a drywaller redo the cracking joints, possible with fiber tape if that wasn't used last time or corner beard, and see if it cracks again. I wouldn't do that until you eliminate the more serious problems.
However, you could have more serious problems.
Some possibilities:
  • if you have an especially wet year, especially in areas with clay or a high water table, expansion of clay soils could cause some lift and settle of the house or the water table could cause a new range of settling. If either problem is chronic, it should be addressed with floating basement walls and/or basement slab drainage. Neither are cheap solutions. You probably know best whether you live in a high water table, a clay soil area, or had a very wet or very dry year.
  • If door and window operation is affected or if enlarged or added any windows, the structural elements around the window or door may have been compromised or installed incorrectly. During an old remodel, I found two previously remodeled windows where the header was unsupported (improperly installed). This could cause some movement in the wall or ceiling around the window, cracking the drywall.
  • If you removed any walls during the remodel, even if you didn't think they were structural, they may have been accommodating some other structural weakness in the house. If you did this kind of work and that is the area that is cracking, you'll definitely need to talk to a structural engineer.
  • Did you convert any flooring from carpet to tile? Tile, especially if properly installed on concrete board, is quite heavy. If some element of your structure was at its load, the tile load could have caused some settling into the new load. I might expect some cracking tile in this situation.
  • Were any roofs lor gutters or drainage systems altered or compromised during your remodel? Is it possible you now have drainage water running next to your foundation etc that was previously safely directed away?
  • If there was heavy equipment or digging on your site during the remodel, a french drain system outside the house could have been crushed or destroyed by the digging or heavy equipment. If you know where water goes into your french drain system and where it goes to daylight again, you could have it camera snaked by a professional sewer cleaning company. You could also try a poor mans trick of filling it with the garden hose. If it doesn't come out the other end, you probably have a problem.
  • Is your water usage excessively? If you have a leaking water main or sprinkler system, which would probably be indicated by heavy water usage, the water could be running underground near the foundation and causing settling or expansion.
  • Last you could have an actual foundation problem. A crack in a slab or a really old foundation (think stone not concrete) could be failing and causing some cracking. If your foundation is visible around the outside of the house (most older homes have some 'freeboard' concrete showing), you might be able to see a problem. Or if you have a crawl space you could examine the foundation in the crawl space. I don't think this is especially likely unless you have a stone rubble foundation.
So those are some very general things that could cause this problem. I'd strongly suggest investing in an hour or two of a structural engineer's time if for no other reason than to sleep better at night. If something really foolish has been done structurally, hopefully they would notice and you could correct it before the problem becomes more serious (structure or life threatening). I'd also consider having a drainage guy out to look at your gutter and drainage systems if they aren't in great shape.
Hope that helps.
The short answer is, 'your house is like a living creature'.
The long answer is with changes in temperature, humidity, barometric pressure and similar, all have an effect on the overall dimensions of different building materials. Generally things shrink when they get colder and/or more dry, expand when they get warmer and/or more moisture rich; however they do this at different rates. The lumber in your walls may expand or contract in greater amount than your drywall does under the exact same conditions.
All this shifting means that gaps, cracks and sometimes even buckling of surfaces (drywall, trim, hardwood floors, etc.) may occur through changes in weather. This can be especially true in places where there is a large difference in temperature between the outside of the home and the inside.
Don't expect ANYTHING to ever remain 100% stable and unchanging through the seasons.
See Here For Specific Rates of Expansion
Inspectapedia.com - Table of Table of Coefficient of Expansion of Building Materials
  • 5
    This is all true, but on the other hand there are many other reasons that cracks might form: water, movement/deflection/settling of the structure, inadequate fasteners, etc. I don't think there's enough info in the question to say for sure.
    – Hank
    Feb 18 '15 at 23:29
  • Good point Henry. I do think 18 months is a sizable amount of time for anything major in the installation to have shown up. It would be good to get more information regarding what might have changed in the house (ice dams, extreme temperatures, changes in roof, etc.) Feb 19 '15 at 17:14
Houses are like living creatures, but I doubt this is the case where "breathing" caused problems. Your problem is to put it in one word poor craftsmanship. Most likely contractor "forgot" to put the flange and on the places where boards are joined crack appears. If that is the case, and from my experience usually it is you should scrape the paint put flange where ever necessary, also apply specialized products for this type of work (knauf's fugenfuller etc.) and pain it all over again. Scraping is so flange would get a better grip on the board, but it is not necessary.
  • From your use of the word, "flange" sounds like what we would call "tape" and joint compound in the US.
    – BMitch
    Feb 19 '15 at 21:34
  • I think they mean the bevels at the top and bottom of a sheet. Butt-joints are more likely to crack unless done correctly (make a ~2' wide bulge all the way along it).
    – Mazura
    Feb 19 '15 at 21:41
  • Sorry,a bit of language bariere.Flange is kind of tape; here is the link there you can see:dragovic.biz/modules/imager.php?w=600&target=a&image=../… Feb 22 '15 at 7:52
