I got this Bergin AC motor which was from a pool pump, but now I want to use it to power a saw.
For this I need to invert its rotation direction. How can I do that by just switching wires?
The four cables at the top just go to the power switch. Unfortunately the metal housing can not be opnened.
12
  • Add Make and Model number of motor to the question please. Appears to be capacitance run motor (White Tube at top of picture). Feb 15, 2015 at 20:19
  • @FiascoLabs i have added a photo of the label.
    – clamp
    Feb 15, 2015 at 20:41
  • Can you take off the connection housing (2 to 4 screws securing it) and post a photo? Let us see the other end of where that pink tubing goes.
    – wallyk
    Feb 15, 2015 at 21:23
  • @wallyk: both of the pink cables go into the dark red tube. but ill take a better photo.
    – clamp
    Feb 15, 2015 at 21:31
  • Where does the connector with the blue, brown, red, and black wires lead? Feb 15, 2015 at 22:01
Single phase, permanent-split-capacitor (capacitor run) motors, like your unit, are normally reversed by switching the roles of the start and run windings. Unfortunately, with the way your unit is wired, it is not possible to make the necessary wiring changes without completely disassembling the motor -- you would have to disconnect the two red wires from each other, then connect the red wire from inside the motor to the terminal that now has the tan wire from the motor on it while connecting the red wire from the capacitor and the tan wire from the motor together, then taking them to where the red wire from the motor now leads.
So, you'll have to head down to a shop that sells motors (industrial-supply places will have them, guaranteed) and get a new motor to power your saw with; either that, or find a way to make your saw work with a motor that rotates the opposite direction from the original.
