I'm trying to plan ahead for an electrical project on my basement. New ceiling lights (recessed and not), corresponding switches and some new outlets. I put a drawing together and I was wondering if I could use your guys' help in figuring out if I'm looking at the project from the right angle and if it's a good approach. Can you take a look at the plan and share any thoughts you might have? Like things I'm doing right/wrong...
Some notes on the drawing itself: the walls in filed with black represent walls I'm adding—new walls. The red represents existing elements (power outlets in this case) where I'm thinking about drawing power from for the new lights, outlets and switches. The green rectangles represent the areas of ceiling drywall I'm thinking of removing in order to accommodate for drilling the floor joists in ceiling from floor above and passing the necessary cables. The joists from ceiling run vertical in the image.
Thanks!
