So here's the situation. I got a shower head:
Problem is that the swivel part is loose, so the shower head just kinda flops down. Is there any way to tighten that part?
Any help/suggestions/links is appreciated.
Sign up to join this communityOn some models the rubber washer helps keep the swivel tight. Check if the grommet has been pushed into the pipe (when overtightened, sometimes they get squished inside the pipe).
