I put a nail thru a new 240V wire, causing a short and the breaker to jump.
Do I need to replace the complete wire or can I cut out the damaged portion and just install a junction box to isolate the cut?
Fundamentally, what I want to know is does a stove wire need to go uninterrupted straight from oven to breaker box or will it work with a joint in the middle?
I just wanted to save on replacing the complete wire, those are expensive...
