I've just moved in my first house a few weeks ago, a new construction, and there is a couple outlets that I want to add and some that I want to move. I'm located in New Brunswick, Canada. There doesn't seem to be any electrical by-laws in my municipality/city, so I assume that I can follow the provincial laws. The provincial act can be found here: http://laws.gnb.ca/en/showpdf/cr/84-165.pdf
First question, there's a couple of data outlets that are not exactly where I need them, that I assume that I don't need any permit/license. They're Cat3/Cat5/Coax combo. I also want to add in an HDMI outlet at the back of the TV mount in the living room that goes down where my amp/HDMI switch is. Since these are all data outlets, I assume I don't need a permit or a license to do that work?
I also have two places where I'd like to add electrical outlets. For example, there's an electrical outlet behind the TV mount, but none down where I'd like my amp, can I just cut out a hole in the drywall, add a box, and fish a wire down from the existing outlet? Is this considered changing/modifying the circuits?
The the provincial act, near the bottom of the document, there's a section for "qualified persons". So it sounds like if you kinda know what you're doing, you can maintain your circuits. However, adding outlets sounds more like modifying the circuits.
According to the wiring permit laws, it seems like you only need a permit if you're going to change more than 10 outlets and/or you're dealing with more than 5kw of load.
I'm more worried about my insurances than anything else. I know what I'm doing, but if I do make a mistake, and there's an electrical fire, I don't want to void my insurance claim.
Can anyone enlight me?
