I replaced an old dimmer switch on an new 7 recessed lights (Outdoor Soffit Lighting Kit 2-Pack) with 6 R20/50W bulbs. The dimmer I bought is Skylark Contour 150-Watt Single Pole/3-Way CFL-LED Dimmer.
Close to it, I replaced an old switch for a Leviton Decora 15 Amp Single Pole AC Quiet Switch.
On the same wall, there is an outlet that doesn´t work after replacement... I have attached a picture before unassembled the dimmer and switch. I have changed the fuses thinking that this was the problem...any help for a desperate woman?
My question is what should I do to make the dimmer, switch and outlet work.
I have attached how the old system was plug...
    The lower left corner is a little blurry, what's that naked single black wire (sort of pointing at us, sticking out over the green wire) supposed to hook to? – Mazura Feb 3 '15 at 23:54
