Not sure on what size stone/gravel i should use, 10 mm or 20 mm in my cement mix 1 cement + 2 sharp sand + 3 gravel (10mm or 20mm) ?
I need to fill 4 gully's in an internal concrete floor, each about 4m length x 0.08m width x 0.18m depth
Thanks
For such a narrow channel, I'd use 10mm aggregate.
You could even go to 4 parts gravel in the mix - a typical "go to" mix ratio for concrete is 1:2:4
  • Is the reason for going 10mm just because of the size of opening? It quite deep though 18cm. – davey Feb 4 '15 at 7:32
  • I wouldn't worry about the depth. The smaller aggregate will be easier to work into the narrow width. – John Feb 4 '15 at 13:57
