I'm planning on hanging a chair from the ceiling. From what I can tell the best method is to add a crosspiece above multiple joists, and mount the chair to that using an eye bolt.
The problem with that is that there is a reasonably large distance between the eye, and the crosspiece.
I can't find a suitable eyebolt (rated to carry a load) that is long enough to cover the space needed. The longest I've found is 225mm overall (so about 207mm ceiling to top of beam). I would need one at least 300mm long overall,
Is this a suitable method, and do eye bolts of the required length exist that will carry the load?
