I had a contractor do some tile work on my house and I noticed the grout is sort of spongy and soft. It doesn't feel like the grout around the rest of my tiles. Anyone know what this could be? Is there such a thing as soft grout?
1 Answer
If it's at a joint between two planes (e.g. wall and floor or inside corner), then it can be colored or even sanded caulk. Using grout in a corner results in cracking as the structure moves, so caulk is recommended for those joints.
Otherwise, you may have an acrylic grout additive to increase flexibility and reduce cracking.
It's between the wall and tile, and also between several tiles. Jan 30, 2015 at 23:06
I agree. All of the builders in my area use the matching sanded caulk even though it will fail/have mold issues for before silicone. However when selling the house it does look better.– DMooreJan 31, 2015 at 6:30
