How much clearance do I need between a wood stove chiminey and the living room wall?
I want to install an antique pot belly stove in the corner of my living room. I'm thinking of attaching concrete backer board to the existing sheet rock and covering that with a brick veneer. If I use a single wall pipe (don't want to loose the heat ), how far away from the veneer does the chimney need to be? What if I use a double walled chimney?
