Four outlets won't work right unless a lamp is plugged in then everything works fine. Unplug lamp it's like not enough power. Plug lamp back in outlets work fine. Why is this happening?
  • Did this start after something was changed like replacing an outlet or switch? – Steven Jan 25 '15 at 13:39
  • most likely a faulty outlet – ratchet freak Jan 25 '15 at 13:55
    What does "not enough power" mean? Can you describe the symptom? – Trout Jan 25 '15 at 14:54
  • The outlets don't work unless the lamp is plugged in – user32075 Jan 25 '15 at 16:05
    What is leading you to that conclusion? There's really not a lot of info to go on. Are you testing it with a multimeter, or something else plugged in? Does this stuff work fine on other circuits? Where are you located (120V or 240V power)? Is your panel fuses or breakers? Are these outlets all on one circuit(controlled by same fuse/breaker)? Are they the only thing on that circuit, and if not, is anything else experiencing this problem? Is there a GFCI or Arc-fault breaker on these, a GFCI outlet in the circuit, or a switch controlling the outlets (all or partially)? – gregmac Jan 27 '15 at 15:23
I am going to guess that the outlet that the lamp is plugged into is the same one each time you have tried this.
You may want to try plugging the lamp into one of the other four outlets. If the lamp does not come on then read on here.
It is clear that the lamp outlet is wired in a daisy chain manner such that power feed comes first to the lamp outlet and then continues on to the other four outlets. The most probable cause of the problem is that there has been a failure at the lamp socket. When you plug in the lamp the tines on the plug cause the metal material in the socket to move around such that the downwind sockets receive power. Remove the plug and the metal moves and opens up the circuit.
This strange behavior almost always happens when the electrical wiring is attached to the outlet using the back stab holes on the outlet. The fix is to replace the outlet with a new one. Attach the electrical wires using the screws on the side of the outlet. There are two good types. One where the wires wrap around the side screw. The other type is where the wire enters from behind and then tightening the screw clamps the wire into place. Both these used with copper wire can provide years or reliable service.
On the other hand the back stab type connections where the wire is poked into a hole to simply be retained by a spring clip are noted for failure and should not be used.
  • 4
    @user32075 - Yeah I heard that. And you should immediately set out to fix this lamp outlet. There is always the situation in a case like this where the outlet fault may develop into something more akin to a intermittent connection. This can lead to sparking and arcing inside the faulty outlet which becomes a serious fire hazard. – Michael Karas Jan 25 '15 at 23:53
