I have one of those cheap Mapp gas + nozzle torches I'm using for sweat sodering and the tip clogged up today. How do I go about cleaning it?
    With most cheap tools, you dispose of it and buy a new one, as they are not made to be serviced. Did you drip solder into it?
    Jan 24, 2015 at 16:38
  • No, definitely no solder in it, it actually worked 10 seconds before, turned it off and prepped the next joint and no hiss when I turned it on. Can still had gas, I could feel it when I shook it. And I tried a brand new can just to be sure.
    – RLZaleski
    Jan 25, 2015 at 1:08
I have doubt it's even the tip clogging - could be a valve failure and have the described symptoms. I have never needed to clean the orifices on a propane torch, and I've been using them (the same ones, for the most part, other than having them walk off sometimes) for decades. Oxy-acetylene, yes - those can and do get sooted up. Propane/propylene-air - never.
Sometimes "cheap" is expensive, and "costly" is inexpensive.
  • I dropped one in the mud once and had to clean it, but otherwise I concur: never have had to clean during normal operation.
    – gregmac
    Jan 26, 2015 at 15:44
