I have a concrete slab and want to put 3/4 wood flooring on top. I'm going to lay a plywood subfloor and want to know if 1/2 inch plywood is good enough. I plan on nailing down the wooden floor.
1half an inch isn't a lot for a nail to grab into and not go through. A one and half inch cleat will go completely through the half inch plywood and stick out about a 10th of a inch. Typically when installing over concrete slab, you float an engineered floor. A high quality engineered floor will look/last the same as a solid wood. – diceless Jan 19 '15 at 20:02
What is your current ceiling height? What is the minimum ceiling height you are willing to accept? – Jasper Jan 20 '15 at 1:32
What about glueing it down? – user31864 Jan 20 '15 at 16:11
Agree with diceless that a floating engineered wooden floor is more normal over a concrete slab. Thermal movement in fully fixed wooden floors causes problematical expansion/contraction more often than not.
Even using stable wood, the humidity in the room will change season to season, as will the temperature of the underlying/surrounding structure, all can affect the appearance of the wooden floor.
Was there a specific design/idea you had in specifying the ply subfloor?
