When I run the hot water to the bathroom sink, as soon as the water starts to heat up, the tap just stops, and I have to give the top bit a few more turns to get it flowing again. It will then usually stop a couple more times, and I find I have to switch it off then back on again to get it flowing again. Happens every time, but only this tap - the bath tub and the shower, both in the same room, are fine.
I've got a fairly new combi boiler (3 yrs), which is maybe 3 or 4 meters from the problem tap (in another room). The pipes going to the basin are a little wobbly, I'm thinking about zip tying them together to make them more stable.
Any ideas on what could cause this?
Happened to me. The rubber washer fell off the bib screw and blocked the valve when it heated and expanded.
Take it apart and take a look.
  • is this in the tap, or the boiler?
    – danwellman
    Jan 11, 2015 at 14:27
  • It was in the tap.
    – Ariel
    Jan 11, 2015 at 23:05
If its the lime deposits expanding with the heat, you might want to try backflushing as described here: http://www.thesuperhandyman.com/?page_id=158 However, take the aerator off the good faucet before starting so that any loose sediment doesn't plug it.
