I'm looking for advice of how to best heat a converted garage space (w/ some insulation). I live in So. Cal and so the lowest winter temp at night is about 40 degrees. Normally I only need to heat the place up a maximum of 10-15 degrees and only at certain times of the day, not constantly.
I've pulled a gas line into the room. One contractor suggested a unit like the Modine Hot Dawg but worry that it may be too noisy (we use the space as an office / guest room). A local heating company suggested a dustless mini split unit which is electric. I've been reading about the benefits of radiant heating units. Would appreciate any tips and suggested sites to visit to learn more.
G2406.2 (303.3)
doesn't allow gas burning appliances in bedrooms unless it is direct-vent type or gets its combustion air from the outside and is separated by a weather-stripped door. – gregmac Jan 6 '15 at 3:24
