Our ceiling has three wires...one white, one black, and one green. The new light fixture we bought only has a white and one black wire. What should I do with the green wire in the ceiling?
The green is the ground wire. If the work box is metal then the box itself should have a grounding screw and you should connect the green to that. Otherwise you don't need to do anything with the green wire.
|improve this answer|||||
    I would also recommend testing the wire to make sure that it's really grounded, before connecting it to the box. – Ilmari Karonen Jan 1 '15 at 21:47
Some fixtures dont have a ground wire - but do have a ground screw where you are supposed to connect to. The installation manual should tell you if that is the case.
